Plumbing with no heater return port on new radiator?
Old Jul 28, 2004 | 11:41 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I know its been covered before, but I'm not confident in the way I plan to plumb everything, so I figured I'd ask. Right now I've got the heater system plumbed like this:
Top of water pump to side (supply) port of the HCV
HCV to Heater Core
HCV to radiator heater return
I've been reading and it seems like the top port of the water pump is a heater return port (for older chevy vehicles). So, when I put in my new radiator (no heater return), I'm thinking I need to route everything like this:
Top of Intake to side (supply) port of the HCV
HCV to Heater Core
HCV to top of water pump (for bypass)
Does this sounds correct or way off?
Thanks!
Old Jul 28, 2004 | 12:16 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: Plumbing with no heater return port on new radiator?
HCV to Heater Core
Thanks!
Sounds like you have it figured out.
Old Jul 28, 2004 | 03:46 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
HCV to Heater Core
Thanks!
Yep, sounds like you have it sorted out. The return hose that would normally connect to the radiator, should get connected to the water pump.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
