85 Iroc overheating... HELP!!!
Old Aug 8, 2004 | 10:16 PM
tjamison2001's Avatar
Car: 85 Iroc Z28
Engine: 305 V8 TPI
Question?! 85 Iroc TPI with overheating problems. Went through 2 gallons of coolant in 3 days. My drivers side floor board is soaked!!! I've been loking in my Haynes manual for a coolant circulation chart and can't find one. Dad thinks it's the heater coil. (not really any good pictures of that either). I've read through previous posts and it looks like it's gonna be a B***H to get at and fix. Any suggestions on fixing this will be a great help!!!! Thanks!!!
Old Aug 9, 2004 | 01:44 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: 85 Iroc overheating... HELP!!!
You can temporarily bypass the heater core by blocking off the heater hoses. The core is accessed under the passenger side kick panel. Then you have to pull it out from there. It can be difficult for a novice but it's certainly doable.
Old Aug 9, 2004 | 07:19 AM
Car: 85 Iroc Z28
Engine: 305 V8 TPI
Is it possible to re-route the hoses to totally bypass the core without totally screwing things up? I really won't need the heater until roughly February (I live in central Florida).
Old Aug 9, 2004 | 10:49 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
I would just replace it and do a good job of it the first time around. That way, you'll have the heater when you need it and you won't have to worry about it leaking for a while.
I bought a replacement heater core from AutoZone ($19.99) and it came with a lifetime warranty.
Old Aug 9, 2004 | 11:45 AM
Car: 85 Iroc Z28
Engine: 305 V8 TPI
Well, I'm planning to get rid of it in a few months and get a Toyota. (Just kidding about the Toyota part) I am planning to get another Camaro and I have had too many problems with this car as it is. Running too rich, needs a new rear end, new carpeting, a lot of body work....... I just don't have the time to really fix all the stuff correctly..... here's a link to a few pics... (be sure not to fall out of your chair while you're laughing)
http://f2.pg.photos.yahoo.com/ph/tjamison_2001/album?.dir=/12e7&.src=ph]
Old Aug 9, 2004 | 11:46 AM
Car: 85 Iroc Z28
Engine: 305 V8 TPI
http://f2.pg.photos.yahoo.com/ph/tja...=/12e7&.src=ph
Old Aug 9, 2004 | 04:09 PM
You can run your hoses to the water pump, thermostat housing or the intake. I'm sure you can figure it out...One of the hoses goes to the rad and the other goes?
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
