Plastic pieces next to air dam
Old Aug 26, 2004 | 01:15 AM
25THRSS's Avatar
Figured I'de post it here since it most likely has something to do with cooling, but I was wondering what purpose those squareish black plastic peices directly next to the air dam are for? One side bolts almost to the front quarter panel and the other side is attached with an actual air dam bolt. I wish I had a pic to better explain it, but if anyone knows what I am talking about, what purpose do they serve?
Old Aug 26, 2004 | 03:07 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I know what you are talking about. Those pieces are all part of the air dam, or so I've been told. The air dam is made up of the center piece (air Dam as you call it, bolts to the underside of the radiator bracket) and the two pieces you are talking about. If they were missing I presume the car would be running hotter.
Old Aug 26, 2004 | 03:40 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What do you call it? A snow plow?
Just messin with ya
Old Aug 26, 2004 | 03:43 AM
gholian's Avatar
Engine: 2.8 V6
Good description man! It does look like a mini snow plough.
Old Aug 27, 2004 | 06:44 PM
25THRSS's Avatar
Just to clarify, the pieces I am referring to are horizontal to the ground, not vertical like the air dam. Mine are there, but they don't seem to serve any purpose. You sure they function to help cool the car?
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
87iroctheo
Dec 4, 2016 11:47 AM
Glowsock
Aug 26, 2015 12:28 AM
Street Lethal
Aug 12, 2015 11:33 AM
