Lower thermostat??? Whats the deal??!
Old Aug 31, 2004 | 03:47 PM
Gr89RS's Avatar
Car: '02 Z06
Hey guys, my 89 will warm up to about 240 everyday before it will cool to 220 - 230 for the rest of the drive,i know this isnt too hot, bot i want to maintain a 220 temp reading. I have an airdam and my (single) fan is set to always run. I want to install a maybe 170 thermostat but ive herd others talking about a chip or something I need to ajust for my system to accept this mod. PLease explain guys, give me as much info as you can. Oh and is running 220-230 going to have any long term effects? Thanks allot!!
Old Aug 31, 2004 | 04:47 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Unsure about '89 but '91 will not perform well if thermostat changed without chip adjustment. Before anything is done, verify temp. gauge reading via a pyrometer. Gauges are not always as they appear. Have the dam ok, factory A/C require Lower Radiator Air Baffle in addition? Good Luck
Old Aug 31, 2004 | 05:35 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Yo, I installed a high flow water pump on my bird with an 180 thermo. It appears as the car gets to about 225 w/ the fan on and than it drops to 160-170, than, due to my bent backward dam, it will heat up a bit. Today in high traffic and 90 degree weather the car stayed cool for an hour, than it got up like air might be getting into the system. Anyway I am not sure if lowering your thermo gets it to turn on as fast, but none the less I would look into it since it seems that lower the thermo the more messed up the guage gets???
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
