Temp. sensor and fan turn on sensor, important?!?!
Old Sep 1, 2004 | 01:08 AM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi, I was just wondering on an 89 305 (lo3 I belive) is the pass. side sensor for the fan, and the driver side sensor for the guage?? Or do they go the opposite way, in the engine?? I might have them wired the wrong way, its possible. Please tell me what should be happening if I did wire them wrong??
Thanks.
Old Sep 1, 2004 | 10:30 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You are right. Passenger side is the fan switch, which tells the secondary fan when to come on and off, and the driver's side is the guage sensor...
No clue on what would happen if you wired wrong...
Old Sep 1, 2004 | 12:06 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you wire them backwards your fan should stay on all the time but run very slowly. Your gauge wouldnt move at all untill the temp that the fan swicth operates. Then your gauge would read max temperature.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
Ozz1967
Aug 16, 2015 10:23 PM
