Fan question
Old Sep 4, 2004 | 09:05 AM
fbodyandy's Avatar
Fan question
i have a 91 TBI RS, and the fan will go on some times on others it will not. i have looked at the wireing diagram and i think the fan control relay is the prob. where the hell is it in the car? i heard that cleaning it off may slove my problems.
a quick pic. would be awsome if some one wanted to help.
Old Sep 6, 2004 | 12:56 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: Fan question
Hard to get a camera in the engine compartment in such a way to show the fan adequately. I have no idea where the fan control relay is. Here's the best I could do:
Old Sep 6, 2004 | 01:45 PM
TpiTony's Avatar
Car: 1991 Camaro Z28
Engine: 305 Tpi (and not the average)
Transmission: 5 spd warner
I got the same problem, PLS HELP
i have a 91 z28 305 tpi and my secondary fan just wont work. ive tried turning the a/c on,and when it gets to 240 in traffic it still doesnt work? so i tried a test light and turnig the ac on and the light will not light up. So i dont think its the fan but i would like to kno where the relay is so i can check it. o if ne 1 can help i would ap. it thx TpiTony
Old Sep 15, 2004 | 06:26 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
fan relays should be on the firewall by the brake booster...
Old Sep 15, 2004 | 09:17 AM
bobsroc's Avatar
Car: 1987 IROCZ
The fan relay is up by the battery in the engine bay behind the passenger headlight. Pop it off and look at the pin connectors, clean them, also look at the plug side connections, same thing. If after you clean it the fan still doesn't work, disconnect the plug from fan, ground one side, jumper 12vdc to the other. The fan should operate, if not, fans is bad. Might want to check the fan switch on the passenger side of the motor under exhaust around the sixth cylinder, make sure the wire is on and making good connection.
Old Sep 15, 2004 | 12:35 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
For a 91 RS, the fan relay is located in between the brake booster and the driver's side fender incased in a small black bracket. There will be 2 relays in there. The fan relay is the one closest to the fender (the other relay is the fuel pump relay). Also, the fan relay has 4 wires to it (while the FP relay has 5).
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
