Yet, another dual fan manual switch question
Old Sep 6, 2004 | 11:21 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
First off, I've done a search..and haven't found exactly what I'm looking for.
I have the Dual Fan set-up on my 91 Z28 Camaro. When I bought the car, the guy wired the passengers side fan so it runs all the time..which is cool. But, I'm wanting to put a switch in so I can run the secondary fan (drivers side) when ever it get's really hot. If I turn the AC on, the secondary fan kicks on, which is normal, but I never run my air and I just want to be able to flip a switch and turn it on and off. I have seen some different schematics and pictures..and I don't really understand those. I was told that I could actually splice into the relay located by the brake booster and run a switch. The problem is...is that I don't know which relay it is and second I don't know which wire to splice into.
If someone can tell me which relay and wire to splice into, I could just hook the switch up to that wire and ground it. Can anyone help and give me some details? Thanks
Old Sep 7, 2004 | 02:07 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...n+relay+switch
the color of the wire i spliced into for my passengers side fan relay was grey because it was coming from the fan switch.
thats the relay all the way on the right of the three next to the brake booster.
so the drivers side fan relay must be the one on the left.
the the furest left relay of the three is the fuel pump relay.
https://www.thirdgen.org/techbb2/sho...n+relay+ground
so i guess the drivers side fan relay ground signal wire is dark green most likely.
https://www.thirdgen.org/techbb2/att...postid=1384183
Attached Thumbnails Yet, another dual fan manual switch question-fanrelaydiag.jpg
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
