Knock sensor help
Old Oct 23, 2004 | 10:54 AM
Robg's Avatar
Car: '85 Z28
Knock sensor help
I went to pull the knock sensor to drain/flush the block and it appears to have broken off in the block. Looks like I'll have to try an ez-out and if that doesn't work, drill and retap. Anyone know what size thread it is?
Old Oct 23, 2004 | 03:14 PM
Robg's Avatar
Car: '85 Z28
Sorry, false alarm. Once I compared the old sensor to a new one, it was obvious that it hadn't broke off. The hole in the block was sealed with scale and junk and the old sensor was pretty eroded on the end. When I pulled it, I was expecting water to be coming out and when it didn't, I freaked.
Old Oct 23, 2004 | 04:05 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, I've seen that once before, went to drain the block in a buddies jeep (350 sbc), pulled the coolant drain plug out (where the knock sensor is on our cars) and nothing.. Have to say that it took me by surprise.. Took a little screw driver and a little tap-tap later, I had coolant gushing out like it was supposed to.. Had a layer of solid crud that completely sealed the area behind the plug..
Old Nov 9, 2004 | 10:13 AM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
would someone be able to describe where the knock sensor is? When i go to flush my coolant i want to take that out to drain averythign too. Im assuming at one of the lowest points but I want to make sure what it looks like.
thanks
Old Nov 9, 2004 | 02:22 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
The knock sensor is located on the lower passenger side of the engine block near the starter. It's located just above the oil pan in the engine block. It's round and has a white connector on it. The car will have to be up in the air to see it. Hope this helps.
Old Nov 10, 2004 | 09:54 AM
Engine: 305ci TPI
yea thanks, i can picture the area your describing, shouldnt be a problem.
i appreciate it.
Old Nov 10, 2004 | 10:21 AM
RedWagon42's Avatar
the knock sensor in the 300 and 350's are almost always a 1/4in NPT which means the hole is little smaller than 1/2 inch... i dont know the exact mesurement.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
