heater core Blues...
Old Oct 25, 2004 | 04:30 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
Well thanks to guys and gals on this site I got my TPI converted to a carb. Well Now AI have discovered another challenge, the heater core cracked on one of the nipple welds. The antiefrees and carpet dose not go well with the car. now for the question
What is the best way to remove the heater core in a 87 trans am?
the TPI is out and it is now a 330 hp 350 just for fun
thnaks rick king
Old Oct 25, 2004 | 08:18 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Are you sure there is a crack? If it didnt leak before you might have a loose hose and need to retighten your heater core hoses first. If the heater core hose is old you may have to cut off the worn part were the clamp was and tighten it on a fresh part of hose. This can cause leaks inside the car while your firewall stays dry.
If you need a new heater core you can pull the passengers side kick pannel floor cover off and remove the rectangular air duct pannel that is below the heater core. You can remove the core bolts (4 I think) and pull the heater core out if you hold the flap in front of the heater core open and be very carefull not to break anything, its all plastic, dont force it. This is a shortcut, I have done 4 ok like this and broke 1. Otherwise you get to take all the stuff in the way apart.
Old Oct 26, 2004 | 09:05 PM
Rick King's Avatar
Car: 1987 TA
I will do that , I wi**** was a hoe=se I know that it is not as I have replaced the heads and put new hoses on it. I wil recheck the hoses just to make sure.
later and
GB
rick
Old Nov 9, 2004 | 11:59 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Dude, I just replaced my heater core and all I gotta say is take your time. my buddy and I used the shortcut on his 88T/a and it did not pay off, although we got everything in half of it was broken. I would not recommend using a short cut if you are doing it the first time. Go get a chiltons or whatever else makes manuals, and take the front dash out. It helps quite a bit. It will take you about 1hr-2hrs to do it.
Good luck bro!
ndndndnd
Sep 28, 2015 08:00 AM
Formula8r89
Sep 22, 2015 04:24 PM
