what thermostat to use
Old Nov 19, 2004 | 12:50 AM
kolkane's Avatar
Car: 91 Z28
I just ordered the hypertech fan switch that turns the fan on at 200 and off at 185, and wondering which thermostat would be best for that?
Old Nov 19, 2004 | 12:54 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I'd suggest a NON-drilled 180* at this point.
Old Nov 20, 2004 | 06:58 PM
kolkane's Avatar
Car: 91 Z28
Any other suggestions, or is 180* it?
Old Nov 21, 2004 | 12:34 PM
LottaBallsCamaro's Avatar
A drilled 180...
Old Nov 24, 2004 | 10:19 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
My car is a 350 tpi. I went with a moderate priced Prestone Thermistat at the recommended temp 190 ...I thought it was, from memory, which I thought was high, but I've been told due to the electronic control, stick with the spec.
The toughest, and w/o a doubt, painstaking task was removing the intake /inlet pipe under the TPI plenum throttle body! I had just done the transverse 4.5 V8 in my '88 Deville. There's no contest as to what is easiest!
I'm not too happy with the effort involved, yet to do heads and intake...likely it will all come off again. I need gaskets replaced and then who knows what else will show up but I'm taking things one by one thus far
Bill
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
