fan wired into ignition
Old Nov 22, 2004 | 07:07 PM
cully6159's Avatar
Car: 1987 camaro sport coupe
Engine: 355
hey i bought my sc from a guy outta ohio and i donno if it was him or someone else who wired the fan to the ignition, so everytime i turn the key the fan is on b4 it is started... havent had any cooling/heating problems yet... i dont think this is a bad idea just wonderd if i should do anything about it or has anyone ever seen this, and wondering if it really will make that much of a differance in the time it takes to heat up
thanks
cullen
Old Nov 22, 2004 | 07:29 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
I dont see anything wrong with it, but being that you are in Wisconsin and he was in Ohio...the question that I have, is will it cause it not to warm up enough for the northern conditions during the winter?
Old Nov 22, 2004 | 07:31 PM
cully6159's Avatar
Engine: 355
well i shouldove said this b4 but weather isnt a factor cuz this is a project car and gonna b for summer use only...so im not to worried about winter driving so i guess the warming up question was short of a dumb question
thanks for your imput
cullen
Old Nov 22, 2004 | 07:52 PM
69-er's Avatar
If it has AC, then it definately needs the fan running until you are at highway speeds. I ordered my '83 without AC, (stupid) so when I installed an aftermarket AC system, I rigged the fan to run continuously except when I'm in 5th gear. I have a micro switch located at the shifter, under the leather boot, that turns off the fan when in 5th gear. Has worked darn good for twenty years.
Old Nov 22, 2004 | 08:13 PM
cully6159's Avatar
Engine: 355
there is no ac in the car i dont really have a use for it its just unwanted weight... i wouldove bought a hardtop if i wanted ac
thanks for the input
cullen
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
