Where is Temp Sensor?
Old Dec 13, 2004 | 10:56 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I went from TPI to Carb. The only guage that I can't get to work is the water temp guage. Since I bought the car without a motor, I'm at a loss. Where was the stock temp sensor on the motor? I bought the sensor that goes on the head but that must be for the fan relay via the computer because plugging it in doesn't get the temp guage to work. Any help would be appreciated !!
Old Dec 13, 2004 | 10:59 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Driver side head, between the 1 & 3 cylinders. At any Parts America stores, TSU64 is the GP Sorenson part number.
Old Dec 13, 2004 | 11:00 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Beat me to it...
Old Dec 13, 2004 | 11:10 AM
wesilva's Avatar
Transmission: 200R4
Thanks, Guys. Is it the one with the oval shaped plug in? I bought that one as per the catalog at my local NAPA. It does not look like the one posted by Stekman in the post titled "Stock Temp guage dead ". That posted sensor has a single blade male. Wrong sensor? Was there a sensor on both sides of the motor at the head? One for the fan relay and one for the guage? My car is a 1985 IROC.
Old Dec 13, 2004 | 11:14 AM
wesilva's Avatar
Transmission: 200R4
It appears that the post "Can someone help identify these sensors? (pic) " has solved the problem. Sorry for not reading before posting!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
