temp guage goes up and down...up and down
Old Dec 31, 2004 | 06:50 AM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
And its been going on since it got cold (so that may be it,double checking to be sure)
Anyway,its got a 180 stat in it and when I warm it in the morning its fine.After I get about 3 miles down the road the stat will suddenly max out and hang for a few seconds (somewhere between 30-60) then drop down to normal.It'll do this 2-3 times on the way to work(about 15 miles).
I've only noticed it in the morning(which is why I thing the outside air temp is involved) and theres never any sounds of "boil over" when its maxed out(the first few times it did it I pulled over to see what was going on).
So could the cold air be causing the stat to try and stick?
Old Dec 31, 2004 | 12:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like a sticking thermostat, not exactly due to an air pocket under it. Try replacing it and see where that goes.
Old Dec 31, 2004 | 02:26 PM
ponykiller's Avatar
Engine: lo3
But it was only sticking when it was cold out(teens-20's).Today its in the 50's and it's fine.
Should I swap out the 180 for a 190 during the winter?Or is it something I can get away with that wont cause damage?
Old Jan 2, 2005 | 03:48 PM
ponykiller's Avatar
Engine: lo3
Hell...just blew my temp theory!It's in the 60's today and it started acting up again. I bought a failsafe 190 to put on sometime this week.
Old Jan 4, 2005 | 04:12 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
:werd:
sheachopper
Jul 31, 2019 11:27 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
