Secondary Fan not turning on
Old Jan 2, 2005 | 12:55 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
After realizing my fans weren't working, I replaced both motors. I tested both before installing, and they work fine.
Now if I jump the AB of the ALDL only the primary turns on. Same thing if I put on the AC. Are both supposed to come on when jumpering?
Does this sound like a wire (or ground) issue? What is in line when jumpering the fans (the relay is bypassed, correct)? Any help is greatly appreciated. Troubleshooting steps would be great. The car is a stock 88 GTA, 305, 5-speed
Kevin
Old Jan 2, 2005 | 09:59 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
As far as i know, the only time the secondary fan turns on is at a predetermined temp that a sensor on the passenger side head is made for. I dont think the secondary even is connected with the ECM. if you want it to turn on sooner you need a different temp sensor for that.
i only have a single fan, but from what iv read im pretty sure.
Old Jan 3, 2005 | 03:15 AM
z28kindaguy's Avatar
Car: 2004 Pontiac GTO
Transmission: M12
You could test your cooling fan switch, that's on the passenger side head. Disconnect the switch, turn the ignition to the ON position, the fan should turn. If the fan comes on and the engine operates at higher than normal temperatures (hot summer day) then your switch is faulty. If it doesn't come on, I would check the relay.
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
bryanwood74
Sep 24, 2015 09:50 PM
Fox118
Sep 1, 2015 04:07 PM
