Help! whats going on?!?
Old Jan 5, 2005 | 07:57 AM
kylem's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 Tuned Port Injection
Transmission: 700-R4
ok guys last night i was driving around in town and suddenly i started smelling a kinda burnt musty smell. I thought well its somethin outside but when i got back in my car after being at my g/fs it was still smelling like that! I told my dad about it and he said it may be the heater core. Can you guys tell me some symptoms of my heater core going out? or if you think its even my heater core.
Thanks,
Kyle
Old Jan 5, 2005 | 01:09 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
is your floor/carpet wet? passenger side usually
Old Jan 5, 2005 | 01:10 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
If you notice the windshield fogging near the vents, you've got another sign. If there's coolant leaking onto the passenger cabin floors (hard to miss) the problem is critical.
Old Jan 5, 2005 | 01:30 PM
kylem's Avatar
i took the a/c and heater fuse out so it wouldnt run. and yes it is a little bit damp but not much
Old Jan 5, 2005 | 02:32 PM
Car: 85 Trans Am
that wont work, its a hose that runs into the car from the waterpump/intake
Bypass or fix quickly!
Old Jan 6, 2005 | 08:44 PM
Jschoepf's Avatar
Car: 1986 Trans Am
Engine: 6.0L LQ4
Well for a while I was having a problem with antifreez leaking on the passenger side. Thought it may be the heater core but the passenger side floor isn't wet... any insight?
