Dual Fans / No Computer
Old Feb 10, 2005 | 05:45 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Ok, I'm fixing to drop in a brand new oldschool 350, carb no computer, all new everything. I'm also going to use the GMPP Deluxe serpentine kit so I'll need to switch over to dual electric fans and dump my belt driven fan. Any suggestions on running
the fans without a computer? Anything I need to know ahead of time?
Thanks.
Old Feb 10, 2005 | 06:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you want dual fans, there are any number of ways you could do it. You could wire them both to be on all the time, both of them on a temperature switch, one on all the time and one one a switch, both of them on different switches with different setpoints...
Old Feb 19, 2005 | 08:15 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
You don't want the fans on all the time. You will fry the fan motors in short order and place a lot of stress on the generator. Use the aux fan switch in a stock dual fan setup and simply drive 2 relays or get a heavier around 40-50 amps relay and drive both fans off it. Make sure the feed wire to the relay is heavy enough for both fans and fuse it accordingly.
Old Feb 19, 2005 | 10:27 AM
JDF-Z28's Avatar
Car: 1983 Z28
I'm looking at wiring / relay kits from Painless wiring and Jet performance. I just got a used dual fan setup from Hawks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
