Temp guage wrong?
Old Mar 1, 2005 | 03:16 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Temp guage wrong?
My temp guage will read at 0 for the first 15-20 minutes of driving. Then all of a sudden the guage peaks. Not gradually, but very quickly. And it won't drop. I think that I have the wrong sensor hooked up. Where is the temp sensor for the guage, and what does it look like? One wire, or two? What color wire(s)? Thanks in advance.
Old Mar 1, 2005 | 12:40 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Driver side head, between the #1 and #3 cylinders. Single male spade terminal, green wire.
Old Mar 8, 2005 | 07:52 PM
stingerssx's Avatar
By any chance you wouldn't happen to know the part #, would you?
Old Mar 15, 2005 | 11:44 PM
stingerssx's Avatar
Found the part #, but I'm wondering if the sender on the right side is switched with the one on the left. What is the one on the right side supposed to look like? The one on the left is a single wire, but it has a connector on it. Not just a spade type either.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
