Low Profile Coolant Resevoir???
Old Mar 15, 2005 | 04:24 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
It there a manufacturer that makes a low profile coolant resevoir? I would like to reduce the height so that i can better fit the passenger side snorkel for my air box...thanks for the help...if you know anyone that has a smaller resevoir, let me know if it worked ok, Thanks.
Old Mar 17, 2005 | 02:02 AM
Night rider327's Avatar
Car: 1988 Camaro
I ues an aftermarket plastic one I bought at advance auto parts for around $7
Here's a pic on mine. http://community.webshots.com/photo/...89828976Tvhisx
I mounted it on the driver's side inner fender. It comes with the little bracket. If you look at the fender close to the horn, you'll see a fender bolt. I took that bolt out. Slide the little bracket between the two panels, then put bolt back. Got a long pc. of rubber vac hose and ran from rad., in front of rad (grill side) zip tied it up, and through core support next to headlights, then over to my bottle.
If you don't like it over there, I think this bottle may also be thin enough to turn side ways and mount in between rad. and battery (depending on size of your battery)
Bubbajones_ya
Jul 6, 2024 08:32 PM
89 formula TPI
Oct 6, 2015 08:40 PM
Linson
Sep 21, 2015 01:08 PM
FormulasOnly
Sep 10, 2015 09:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
