leaking coolent?
Old Mar 21, 2005 | 06:34 PM
808RS's Avatar
Car: 91 RS
Engine: 305TBI
leaking coolent?
i had a cracked radiator so i changed the radiator but left the orignal hoses and only changed the clamps. the temperature seems to be normal but this morning when i checked my car i noticed that i had a trail of fluid on the ground. any ideas of what may be the problem?
Old Mar 21, 2005 | 07:24 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
might want to check those clamps again and the position on the hoses. double check wont hurt, you know what i mean yo!!
Old Mar 21, 2005 | 09:43 PM
Stevo's Avatar
Car: Pair of 92 Z28s
could have over tightened the clamps and broke the plastic piece that sticks out into the hose...
Id water it all down then dry it off completely with compressed air then let the car run and feel around with ur hand or just watch it.
Old Mar 21, 2005 | 11:59 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
or you can do a pressure test on your cooling system to see where the coolant comes out from. pretty cheap and i think they have it at the autostores. best bet bro!!
Old Mar 22, 2005 | 06:20 PM
808RS's Avatar
Car: 91 RS
Engine: 305TBI
is there any chance it could be my waterpump? and if so how could i check it?
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
