Overheating ???????
Old Apr 4, 2005 | 01:06 PM
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
Overheating ???????
im having this problem where my cars will temp gauge will steadily go up til it overheats and the fan never kicks on. I can put the ac on and the fan will turn on and the temp gauge will slowly go back down. Could it be the fan switch or the thermostat?
Old Apr 4, 2005 | 02:18 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
It is the fan switch.. Either the switch is non functional or the wiring hooking up to it has gotten too hot and broken off... Either one or a combination of both is the cause... The fan switch is located between the 6 and 8 cylinders on the passenger side cylinder head.. See this for more information on which switch to get: Radiator Fan Switch Alternatives
Old Apr 4, 2005 | 08:08 PM
Car: 1989 RS
Transmission: WC T5
am i going to have any problem putting this part in or is it just going to be swap it out and thats that. Just making sure i dont have anything to look out for. thanks
Old Apr 4, 2005 | 08:20 PM
thirdgen88's Avatar
Car: 1995 Corvette
Repairing any damaged wiring (that connector sometimes gets brittle and breaks) will be the only additional effort.. The old sensor will unscrew and the new one will screw in.. Might drain the coolant from the block first using either coolant drain at the bottom of the block (one is plugged, the other has the knock sensor in it) to contain the coolant that will come out..
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
