coolant leak, pics included...
Old Apr 6, 2005 | 04:47 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
I did a search, but did not find an answer.
My car is leaking coolant and I think it might be the water pump. It appears as though the coolant is leaking from the top of the big hose attached to the lower part of the radiator on the passenger side. I have attached a couple of pics for the pros. Unfortunately, my jack is in storage so I could not get under the car. Thanks for any advice.
If it is the water pump, any advice re: which brand to get?
The pics are too big to attach, so you can check them out here:
http://pg.photos.yahoo.com/ph/specin...bum?.dir=/3de4
Old Apr 6, 2005 | 11:28 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
It could be the water pump. just check all your hoses to make sure they are snug. Aslo another thing you can do is a pressure test to see where its coming out from.
Old Apr 7, 2005 | 12:04 PM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks, I'll definitely check the hoses one last time. How tough is it to run a pressure test?
Old Apr 7, 2005 | 01:29 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
not hard at all. you just take your radiator cap off and put on the pressure cap on there and pump air into it. they should have them at the auto stores. good luck bro
Old Apr 12, 2005 | 04:31 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thats coming from your weep hole on the bottom of your water pump. If you replace it PLEASE dont use the "paper" gaskets that come with the autozone pumps. I missed 2 days of work b/c i though that i wasnt putting the pump and gasket on right. I used just some rtv but i dont recommend it.
Old Apr 13, 2005 | 11:02 AM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks. That's what I thought, but it is always nice to have additional confirmation. I am going with a stewart water pump and I'll make sure to avoid the paper gasket.
TheExaminer
Sep 6, 2015 11:40 PM
mantaguy
Sep 2, 2015 10:42 PM
tonys91rs
Sep 2, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
