is it worth the risk for ebay electric fans?
Old Apr 8, 2005 | 09:20 PM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
or electric fans in general. With a mechanical fan, I am sure that it is working, but if a motor goes out on my dual setup, then, I would not know untill it overheats.
I am wondering about the 20 dollar electric fans on ebay. Are they worth it. I have a flex, and another with a clutch, so that would be the cheapest alternative.
I really want electric fans, because it has bragging rights.
This is available for $27 buy it now
Description
RADIATOR UNIVERSAL ELECTRIC MOTOR COOLING FAN FOR COOLING AIR CONDITIONING SYSTEM . REVERSABLE. .AVAILABLE ALSO IN SIZES 9,10,12 OR 14 INCHES, COMES WITH MOUNTING HARDWARE, BRAND NEW. VALUED AT OVER $90.00. 12V, 12.2AMP.SPECIAL SPRING APRIL SALE
would a couple of these 14" fans be reliable?
I don't want to spend the cash on brand name kits, but is this a "get what you pay for" situation?
I also have a stock aluminum rad. I have a copper, or brass one, out of another thirdgen, so would that be better?
I don't have cooling problems, but I want it to work better, I guess. Also the few measly hp from getting rid of my mechanical fan is a big incentive.
Thanks for your help.
Old Apr 10, 2005 | 08:45 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
all i kno is that my fan (elec) is takin its last days badly.... i can tell when its not on by my voltage gauge...
Old Apr 10, 2005 | 11:18 AM
so if I just watch my volts, I can get an idea if my fans are starting to go out. I figure I am going to get 2 14 inch fans and wire them up with a toggle. I am going unshrouded, so would it be best to go with a pull or a push setup. It can be reversed, but I remember that if they are behind the radiator, that one is better than the other.
Old Apr 10, 2005 | 06:11 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
if they are on the engine side of the radiator the MUST be in pull config... otherwise teh fan would be fighting the oncoming air from the road.
i know that my car runs at just over 13.5 with my fan toggled to on and like 14 or so with it off... i know exaclty when my fan is on or off
Old Apr 11, 2005 | 11:30 AM
Alright, I am relieved. As long as I watch my gauges, I should be okay then.
Thanks saigon-bob
Old Apr 11, 2005 | 02:54 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea.. if anything.. you will see you temp gauge rise when the fan is off letting you know to check it out
Old Apr 13, 2005 | 11:26 AM
So are the ebay fans worth it? Unshrouded?
Old Apr 13, 2005 | 11:37 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
No. You would have to mickey mouse this setup to get it to work. You are better off getting a factory single or dual electric fan setup, with the factory mounting brackets etc. The install will look much cleaner, and if you get it from the junkyard, you could probably score the factory wiring also.
Old Apr 13, 2005 | 02:23 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
in my car and another random camaro i saw.. ( we both had the same electric fan(stock)) there is no shroud....
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
e3pres
Sep 9, 2015 01:51 PM
64goatman
Sep 9, 2015 01:09 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
