82 LG4 carb intake to 86 TPI, coolant lines?
Old Apr 10, 2005 | 07:19 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I just noticed that the coolant lines for my 82 LG4 go into my intake manifold, while for a tpi the go into this piece, not sure what it's called. Is that the only thing I would need as far as those two lines coming out the firewall?
Old Apr 10, 2005 | 07:20 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Forgot the pic.
Attached Thumbnails 82 LG4 carb intake to 86 TPI, coolant lines?-tpi-maf-engine1.jpg
Old Jul 8, 2006 | 11:56 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
anyone?
Old Jul 9, 2006 | 10:30 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That is a heater valve. This part isn't neccessary. Many people delete it. You could run one hose to the lower intake and the other to the radiator.
Old Jul 10, 2006 | 12:46 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
What does the heater valve do?
Old Jul 10, 2006 | 01:18 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
It blocks off coolant flow to the heater core. It is supposed to cut flow to the core when vacuum is applied. It is supposed to also act as a safety if your heater core fails. The plastic valves fail more often than the heater cores.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
