water pump question
Old Apr 17, 2005 | 11:57 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
water pump question
anyone know if a stock v8 water pump from an 86 model has accessory mounting holes on the pass side? i am looking at a alan grove alt bracket and it looks like it mounts to accessoy holes. ( i am using an 86 model because i am using v belts and the outlet is the right size as my rad.) thanks
Old Apr 27, 2005 | 04:37 AM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
it should have two holes at the botom for the smog pump/ batt ground bracket and one on top for alt bracket (pass sd respectively)
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
