What is wrong with my AC Compressor?
Old Apr 18, 2005 | 07:30 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
My AC works, it blows nice cold air. The guy I bought the car from had put in a new AC Compressor, probably by himself. The problem is, my compressor kicks on and off and on and off constantly! Probably about 4 to 5 seconds between the on and off stages. It is really annoying, it causes the RPMs to go up and down when it happens. What do you think the problem is??
Old Apr 18, 2005 | 08:41 PM
Firechicken91's Avatar
Car: 1991 Trans Am
Engine: 350c.i. TPI (coming soon: 357c.i. TPI screamer)
Sounds like you could be low on refigerant. If you have access to a set of R-134a guages, check your high and low side pressures. The manual says with the engine at 200 RPM, low side should be roughly 30-45 PSIG, depending on temp & humidity. High should be roughly 160-350 PSIG, depending on temp & humidity. These numbers are for R-12, but should be almost the same for R-134a.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
