size of rad?
Old May 10, 2005 | 08:12 PM
A88GTANotchback's Avatar
size of rad?
i cracked my rad the other day so im going with a aluminum griffin one to replace it. my question is what size rad came factory in a L98 in 1988. the cars a GTA if that matters.
Old May 11, 2005 | 12:10 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Get the griffin 31x19, a little work to get it in (Use the BFH)
Old May 11, 2005 | 12:53 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The 31"X19" takes a little wedging to get it to fit, like mention'd earlier. Here's a good thread with pictures of the OEM radiator next to the griffin along with what has to be done to install it.
https://www.thirdgen.org/techbb2/sho...hreadid=255817
By the way, becareful which core size you get (you'll find out all about this in the thread).
Old May 11, 2005 | 07:18 PM
the guy im getting the part from tells me there are a few options. 19" H x 3" W x 22, 24, 26, 27.5 or 31 are the sizes so i wanted to get the one that would fit best. if i can get it close without modification thats the way i want to go but if worse comes to worst then ill go with the 19 x 31
thanks in advance.
Old May 14, 2005 | 10:14 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I sent a lot of PMs out about this also and it seems to me that a 27" X 17" would fit better. Or 27X16 or 26X16?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
