irratic overheating?
Old May 14, 2005 | 02:30 AM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
while driving i noticed my temp just instally soared to as high as itll go so i quicktly pulled off the road and turned the engine off...put some more water/anitfreze into the resivor..started again it was down to 180 then once again soared quickly...
soo...i opened the radiator cap(the one where it warns u of pressure...ect) n i was thinkin i would get soaked in hot water n steam, but there was no pressure or spraying of water or steam. i put the cap on started the car and the temp was down to 160 and running fine, even drove it home with no abnormal temps.
could this be just a freak accident bc of the guage? or mabye a failing thermostat?
Old May 15, 2005 | 10:44 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
I have the same problem and no one will help me either. Someone tell us PLEASE why doesnt my cooling system have pressure????????????
Old May 24, 2005 | 09:24 AM
Whitels1's Avatar
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
off the top of my head I would say that your t-stat is sticking. Picking up a new one for 5 bucks couldnt hurt, if you are running a standard fan with a fan clutch, your fan clutch could be toast. If you have electric fans you could have a bad relay, fan or an electrical problem.
I would start with the t-stat, and fan clutch. Those two are usually the culprits. You should also make sure your overflow has reserves at all times.
Good luck
Dave.
Old May 24, 2005 | 04:03 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Ummm, no pressure when you opened it? When the engine was hot that is not a typical sign. Verify the gauge is correct (Close enough) as well as the rad cap.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
