Fan on @ 250 in 91 rs
Old May 15, 2005 | 02:55 PM
acidpad's Avatar
Car: 1991 RS
Engine: 406 in progress
Transmission: th350
My electric fan doesnt pop on til about 250* and then turns off around 210*, i called autozone and asked if they had the cooling fan switch, and what * they turn on / off at, and he had no clue what temps they turned on and off at. Is the problem most likely the cooling fan switch, and where can i get one that turns on fairly early, like 200* or so ?
Thanks.
Old May 15, 2005 | 03:50 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
hypertech and jet chips both make switches that turn on at lower temps
change your thermoustat to a 180 if you use one
Old May 15, 2005 | 05:16 PM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
So I will need a new Chip to do this ? Its normal for the fan to turn on at such high temps ?
Old May 16, 2005 | 07:18 AM
350 TPI's Avatar
Its always been my understanding that the factory settings were extremely high for the fans to kick on.My gta gets so high that it worries the crap out of me.I think the reason the factory set the fans to kick on so high had to due with passing emissions.The higher the temps the lower the emissions.Unfortunately this has adverse effects on the engine.Just get a chip buned that cuts the fans on at a lower temp.Thats what i plan to do.
Old May 17, 2005 | 12:01 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
i have the same issue. fan turns on right before the red about 140*. i have digital gueags so u dont know exactly what its at.
Old May 22, 2005 | 01:12 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Mine doesn't turn on till 260... All the way in the red... Scares the crap out of me... It turns off at about 230 to 240 (when it should turn on)
The fan is set to turn on at 240 from the factory.
I changed the fan switch/temp sending sensor... No change...
Run fan to power, it works fine... Jump the diagnostic terminals, fan kicks on (so I know the computer is communicating with it)
when it sits at 260, there are no problems, it doesn't idle rougher, I'm not getting anything in the overflow tank (radiator cap tested ok too), and there is no real loss of power that I can notice.
It never steams or smokes, and doesn't even really smell hot.
I think a widely overlooked fact on these boards is that the TEMPERATURE GAUGES ON THESE CARS ARE NOT THAT ACCURATE AFTER 15+ YEARS... lol
Old May 23, 2005 | 11:02 AM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
yeah .... but mine idles rougher and smells hot when its at 250/260, so that doesnt make me too happy.....
Old May 26, 2005 | 11:29 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
fan switch options
Click this link to see what temps the fan switches turn on at, and then decide which one you want to buy. Bear in mind that our factory gauges suck pretty bad. They are usually about 20º on the high side. So if you gauge is reading 250º, chances are, if you check with a scanner, the CTS will be reading 230º, or lower.
Old May 26, 2005 | 09:05 PM
acidpad's Avatar
Car: 1991 RS
Transmission: th350
Ok, with those though, do you need to get a re-burned chip ?
Old May 27, 2005 | 01:37 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Ya know, I wasn't even looking to see that yours is a v-6. I don't think those fan switches are going to be an option for you. I believe the fan for the v-6 may run off of the chip by way of the CTS. So, you just might have to have a chip reburned to take care of your problem. But I seem to remember someone on here talking about an aftermarket fan wiring kit, that allows you to adjust the on-temp, even with using the stock prom.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Night rider327
Sep 25, 2015 04:47 AM
