Anti-Freeze/Coolant
Old May 26, 2005 | 02:36 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Anti-Freeze/Coolant
I have a 305 that is getting really hot all the time now, I think it was because the it was leaking alot of anti-freeze/coolant out of the thermostat housing. I fixed this problem by buying a gasket and sealent and sealing this all over again, then I added water... I know Water will rust my engine over time, but replacing water for anti-freeze/coolant could this cause the tempature to rise? or is it something else?
Fan Works and there is no leaks coming out from anywhere
Old May 26, 2005 | 03:15 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Are you losing water? If so, it's probably a blown head gasket....
Antifreeze/coolant will not cause your car to run hotter-it only
prevents rust and corrosion, lubricates your water pump and will
help increase your boiling point (with the appropriate pressurized
radiator cap).
