overheating 240+
Old Jun 6, 2005 | 12:12 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
overheating 240+
My car is overheating 240+, the radiator is full, no leaks, kind of a anti freeze rich mixture. How can i get the temp down? I live in philly and its like 90 so that helps, but i get this problem often.
Old Jun 6, 2005 | 02:18 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
When does the car overheat? Idling, low speeds, or high speeds
Have you visually checked to make sure your Air Dam is in place? If there isn't a plastic flap under the radiator at highway speeds the car will slowly overheat. Since these cars have limited or no (firebirds) grille area most of the air is deflected into the radiator area by the air dam.
You might also want to check to make sure your fans are kicking in if they're electric.
Might also what to take the time and check the thermostat maybe it failed in the closed position.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
