Radiator cap pressure
Old Jun 28, 2005 | 04:57 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
New thermostat and gaskets on the way .. ordered them .. so when I flush the radiator I'll probably just go ahead and get a new radiator cap as well .. now .. question is ...
standard pressure .. or.. get a slightly higher pressure (like 2-5 lbs higher pressure than stock) ... good or bad ? (probably opened a can of worms on this one lol)
The engine's a stock 305 TBI ... L03 ... '91 Camaro RS
The thermostat will be a highflow 180 degree
Old Jul 8, 2005 | 09:24 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
pressure test your cap, if it passes, just reuse it. theres no need to raise the pressure, all your doing is raising the boiling poing 3 degrees for every psi.
Old Jul 8, 2005 | 10:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What he said. There's no gain from a higher operational PSI for the cooling system. Just keeps fluids in the actual "usable" system longer in the event you start to get toasty under the hood.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
lakeffect2
Aug 23, 2015 08:44 AM
