car heats up at high speeds what can i do to stop this
Old Jul 5, 2005 | 10:47 PM
383stroker90RS's Avatar
Car: 1990 camaro RS
Engine: 383 stroker
Transmission: turbo 350
i have a 500hp 383 with th350 behind it right now im running factory gears so im not winding this thing up i went about 350 miles across florida with this thing and everytime i would hit above 3500 rpms (75mph) this thing would start heating up so this was a real problem i have replaced the air dams baffles and all that stuff any suggestions im thinking a bigger fan may help this problem what do you guys think
thanks russ
Old Jul 6, 2005 | 05:18 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
A bigger fan won't help anything at speed; there should be enough airflow at 75 to have the fan turning at a good clip all on it's own.
Are you using a stock rad? What temp is the thermostat?
Old Jul 6, 2005 | 07:16 PM
Car: 1990 camaro RS
Engine: 383 stroker
yes im using a stock rad for a Iroc and 195 thermo the rad is brand new its only about 2months old
1992 Trans Am
May 10, 2023 07:19 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
