AC acting weird
Car: 91 Z28
Transmission: 700 R4
AC acting weird
hello guys, allright heres the deal, number one, when im at a stop light, the car blows warm air, but the faster i go it gets cold, only at stops or low speeds it blows warm. number 2 instead of blowing out the vents everything blows out of the top of the dash like where the defrost blows, any help is greatly appreciated, thanks
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
1) Check cooling fan(s) for proper operation
2) The ductwork is controlled by air doors operated by vacuum diaphragms. Check first for a disconnected vacuum line in the engine compartment, and check second for a vacuum leak in the climate controls (above the stereo). If it's leaking vacuum, you should be able to hear the hiss.
RedLeader289
May 28, 2019 01:47 PM
