Cooling Fan
Old Jul 30, 2005 | 07:36 PM
chargers21's Avatar
Car: 1987 Camaro RS
Engine: V-6 2.8
Cooling Fan
Hi,
I have a 1987 camaro RS, V-06 2.8 liter. My cooling fan stopped working the other day. Before I noticed that it went out, I smelled a electrical burning smell coming from the engine compartment. I looked on the left hand side of the radiator and noticed that a red wire had burn itself through. I took the Camaro to a auto electric shop and they diagnosed that a plastic bag had innertwined itself on to the fan motor and caused the fusible link to blow. They fixed the problem, so I thought. The next day the electrical buring smell came back and I noticed the cooling fan stopped working and the same wire had fried through again. Before I take it back to the shop on Monday does anyone have any ideas?
Tim in San Diego
Old Jul 30, 2005 | 08:36 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'd guess the fan motor has fried it's windings, almost a dead short maybe. Or a wire is touching a grounded metal piece somewhere in the circuit. They should be able to easily diagnose this one way or the other.
Old Jul 31, 2005 | 01:11 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yeah, if you lock up the motor, then apply power, it will certainly overheat. You probably fried the fan motor. Head to the JY and get a replacement. You probably should replace the fan relay as well. In addition to the burned wire.
Old Aug 1, 2005 | 10:36 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
Before going to the JY, if you have a parts place you use, check with them. I looked on the WEB at a discount GM part, and it was $104.50 for a universal replacement fan motor. I stopped at my friendly parts shop today, and they had one on hand (not GM). List at $60.00, my price about $33.00. Might be worth going with a new one.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
