Which fan is supposed to come on first?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Drivers or passenger, in a dual fan set up of course.
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Fan
Hi,
The fan that is programmed to come on at the lowest temp.
Secondary thru head fan switch or primary controlled thru ECM
by the chip setting.
Or turning AC on. Which one AC not sure as not running one
on this end.
Later
jaykar
on this end.
Later
jaykar
Fan
Hi,
Rite,
Was talking about if altered setups such as alot of the cars
in these posts are.
Including mine.
Later
jaykar
Rite,
in these posts are.
Including mine.Later
jaykar
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
