i think i damaged the A/C?
Old Aug 22, 2005 | 10:15 AM
Firebat's Avatar
I dont know its proper name but its the A/C blackbox that is on the firewall. I beleive it is where the fan of the A/C is located. Anyways, when i dropped in the LT1 with the shorties on, i must have hit that box. It took off like a square inch of plastic and there is like a screen showing behind the square inch hole.
What would be a good way to fix this? Or do i have to replace the whole thing? Note: it is really close to the headers.
Old Aug 22, 2005 | 10:22 AM
Firebat's Avatar
I know you can use MEK to repair minor plastic stuff. Would that be a good idea though being that close to the heat coming off the headers though?
Old Aug 22, 2005 | 10:36 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I used flexible bumper repair from Autozone to repair mine when it cracked. If you damaged the top piece then replacing it is simple, the bottom takes a bit longer but its not really hard either.
Old Aug 22, 2005 | 10:38 AM
Firebat's Avatar
its more towards the bottom. Thanks, I'll check out Autozone.
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
