A/c Doesn't blow cold
Old Aug 24, 2005 | 12:32 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
So i replaced every component of my a/c system(evap core, heater core, condenser, orifice tube, compressor, lines, etc.) I charged up the system with some freon and when I went to turn the a/c on it only blows hot air, and all the time whether the a/c is on or off. I know that this has to be a blendor(sp?) issue so I checked it and sure enough the door doesn't seal shut all the way. So i figured I would put a manual shut off valve in the heater hose line that circulates into the heater core and it should blow cool since it wasn't recieving any hot coolant. Wrong! It's still blowing hot air all the time even with the valve shut completely. Any ideas/suggestions. I'm tired of burning up in my car
Old Aug 25, 2005 | 09:19 AM
anyone?
Old Aug 25, 2005 | 09:27 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
First thing to check, is the compressor actually turning, look at the center of the front pulley on the compressor, it has to turn. If so, feel the aluminum receiver/dryer tank just in front of the AC box under the hood, it should get real cold and sweat from water condensing on the outside. If all this is happening, you may have an airlflow diverter dashpot not working right. Some of those are really hidden in the dash too.
Old Aug 26, 2005 | 01:58 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Bad pressure switch maybe.
Old Aug 28, 2005 | 11:55 AM
Yeah I checked to make sure the dryer tank was cold and sure enough it's a block of ice. I also stuck a thermometer into the evap core box and it's reading around 45 degrees on the inside so I know everything is functioning properly. And yes the Compressor clutch is engaging properly as well.
Old Aug 28, 2005 | 11:51 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Next thing to check would be to see if you have vacuum to the controlls. Put the fan on high and put the AC into the max position, should hear it get much noisier when the door opens, then try the defrost setting, air should go to the windshield. If this works you're pretty much down to one air door operator I suppose that's holding the cold air out of the system.
diana227vegas
Jul 8, 2016 12:27 AM
Matt86IROC
Sep 7, 2015 06:30 PM
Victor6
Aug 30, 2015 02:09 AM
