forget coolant route?
Old Aug 30, 2005 | 02:50 PM
F-BOMB's Avatar
I have an 85 tpi V-belt set up. Originally a 305, but now is a 383 with tpi set-up. Its been 3 years, lifes goes fast, since I built the motor and forget coolant routing. Also the 3/4" threaded hole at the top of the water pump, is it supossed to be pluged or is it used. I f someone could just give me the info, or a diagram that would be great. I will probably by-pass the TB, but I really need to know about the top of the water pump and the coolant route. Ex. top heater core to where?..etc. Thanks, its been a while, but is still fun.
Old Aug 30, 2005 | 03:49 PM
F-BOMB's Avatar
Thanks for helpin me out guys. Ya look at the post but don
t respond. C-mon this is an easily answered question, just look at your stock tpi set up. I've looked in hayes and chilton, which suck, and there are no good diagrams or pictures.
Old Aug 30, 2005 | 04:57 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
lower radiator/passenger > Pump > Block > Heads > Upper radiator/driver
Like that?
I dont have TPI but on mine the fitting is for the heater core line. i think the tpis route it from manifold > heater > radiator
Good luck
Old Aug 31, 2005 | 05:16 PM
F-BOMB's Avatar
Forshock 85TA thanks for the reply, Ive got it figured out.
Old Aug 31, 2005 | 05:17 PM
F-BOMB's Avatar
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
