Waterneck leaking bad HELP!
Old Sep 3, 2005 | 10:13 PM
Blue_IROC_86's Avatar
Car: '82 Camaro Z28 (Former Pace car)
Engine: 85 5.7L Small Block
Transmission: WC T5
Axle/Gears: 96 disc LT1 3.23 Auburn 10 bolt.
a bolt snapped off the water neck. and i wanted to know if there anyway i can fix it without bringin it to a shop to have them drill it and tap it. if theres any way to do this please let me know!!!!!!!!!!
Old Sep 4, 2005 | 11:13 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Get the bolt out yourself.
Old Sep 5, 2005 | 03:47 PM
Transmission: WC T5
how am i supposed to do that?
Old Sep 5, 2005 | 05:21 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Take it to a shop
Old Sep 5, 2005 | 05:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
E-Z outs work good. If all else fails, you can drill the bolt out and re-tap.
Depending on where the bolt snapped, you might try grounding the sides down and vice-gripping the remaining bolt out.
Old Sep 7, 2005 | 04:03 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Did it break flush with the surface or deep in the bolt hole?
If it is flush with the surface, try cutting a slot or even and "X" in it with a dremel and use a flat head or phillips head screw driver to get it out.
Old Sep 7, 2005 | 06:39 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
if i were you i would take it to a shop,the exact same thing happened to me and i tried the same advice you were given here...2 weeks later i had to install a new intake manifold
(at least it was an edelbrock)
xxx3man`
Sep 23, 2015 10:37 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
mike_c
Aug 27, 2015 04:32 PM
