fan quit working?
Old Sep 6, 2005 | 10:04 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
fan quit working?
my fan has quit coming on at all...i have replaced the fan switch(i think)..i dont know how many componets work together to make the fan come on...can anyone give me any insight...thanks...I have the fan wired to a relay and a switch inside the car and turn it on when it reaches about 195 but i would like it to work like it is supposed too
Old Sep 9, 2005 | 02:42 AM
1a12's Avatar
Did you use the original relay for the fan, OR did you purchase a new one. If you used the old one, the i would say the relay works as well as the fan. I would look at the fan switch again. Make sure the terminals aren't dirty. next, i would check to see if the computer is turning the fan on. Not sure if controlled by the computer or not. I think it is. Check the wiring as well.
Good luck
Old Sep 9, 2005 | 08:54 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Re: fan quit working?
So neither the coolant fan switch or the switch inside the car will turn the fan on, correct? First thing I'd suggest is to turn on the AC and then see if the fan comes on. That will help eliminate certain things depending on whether it comes on or not.
The cooling fan on these cars are not controlled by the computer, only the fan switch and AC pressure switch? (it's one of the AC sensors, can't remember which one exactly) will turn the fan on.
Old Sep 9, 2005 | 10:20 AM
homerunchamp's Avatar
Car: 2007 Dodge Charger R/T
Engine: 5.7L HEMI
you said you replaced the fan switch, but are you sure? I did the same thing then came to find that the switch is in the passenger side head, the one on the driver head runs the gauge, the one in tha intake manifold something else. So the culprit is most likely in the passenger side head, which leads to my question that no one has yet answered. What size switch do our cars run? On line auto shops list two different ones, a 9/16 and a 5/16" one. So best of luck to you.
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Leggman1
Aug 6, 2015 04:15 AM
