Temp Guage Not Working
Old Sep 25, 2005 | 02:30 PM
383vert's Avatar
Car: 91 Firebird, 92 Trans Am, both convertibles
OK, I replaced the Coolant Temp Sensor, the Temp Sending Unit, the Thermostat and coolant. The fans come on, but the temp guage on the dash still reads 100. When I start the car, it surges all the way up to red then back down to 100. I took it around the block a couple times and let it sit and run and still doesn't go up at all. This is on the TA.
Old Oct 2, 2005 | 02:05 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i had the same symptoms with mine. i replaced the guage with an aftermarket one and it showed the car warmed up nicely. even in stop and go traffic mine never seemed to go much above 100-110.
Old Oct 3, 2005 | 06:10 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
well i have a problem with my gauge as well, but my problem goes further than that i think, it will do a full sweep test...sometimes... and then it will randomly bounce around like a spring in it is broken. Secondly my car seems to run much hotter than my radiator does, and when i am inside the car cruising at low speed i hear a whine noise, that sounds like a turbo, would that be my water pump going out?
Ghettobird52
Jul 5, 2024 11:18 PM
TheExaminer
Aug 26, 2015 04:59 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
