quick question
Old Oct 4, 2005 | 07:20 PM
redcamaro1989's Avatar
Car: 1989 rs RIP, 96 grand marquis, 92rs
Engine: LO3, 4.6l, L03
Transmission: 700r4, AODE,700r4
Axle/Gears: 2.73, 3.08, 2.73
quick question
what does the diffrent temp. thermo. do. 9i have a 195 in mine i belive. i live in georgia and it is on average about 75 to 80 degrees. should i run a lower thermo. like 160 or 180 and what diffrence will it make
Old Oct 4, 2005 | 09:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
these engines are designed to run hot. Running them hotter means running them cleaner as the hotter the engines (within limits, of course) means less emissions outputs. All a lower thermostat will do is circulate the coolant at a lower temperature - aka run a little bit cooler. 180 is fine, personally i wouldnt venture much lower.
Old Oct 5, 2005 | 02:58 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Anything lower than ~180* will probably make things worse unless you start reprogramming PROMS for the ECM.
Old Oct 5, 2005 | 05:25 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I run a 180 in mine. Runs fine, passes smog. IMO the engine will last longer if you run it a bit cooler, but not too cool.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
