i've done it now, punctured my radiator
Old Oct 22, 2005 | 08:03 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i was cuttin a one of those plastic ties you use to keep wiring together, and i slipped with my knife and hit my radiator. it didnt hit all that hard, but apparently it was enough, it started leaking coolant. does the metal based stuff they sell at autozone and places like that actually work for sealing up small radiator leaks, or do i need to start looking for a new radiator? (again)
Old Oct 22, 2005 | 08:10 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
a local radiator shop should be able to fix the leak for you pretty cheap. I would stay away from those stop leak products as they tend to clog things up ,and dont last, in my opinion.
Old Oct 22, 2005 | 08:12 PM
1meanGTA's Avatar
anything i can do to patch it up temporarily? the car is about to be towed about 15 miles away on wednesday, and i was planning on driving it back. i could take it straight from there to a radiator shop.
Old Oct 22, 2005 | 08:25 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I saw a post about fixing your radiator using something like JB weld (a very firm epoxy material). Basically drain the coolant, clean area thoroughly, apply epoxy, let sit 24 hours, fill the system. Probably what the radiator shop will do atleast.
Old Oct 25, 2005 | 11:51 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
solder.... (or hillbilly saudier )
Old Oct 26, 2005 | 05:32 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
If the cut is not to big and is accesible, solder it in the car. Or drain the coolant, remove the radiator and solder it. Assuming you have a solder iron and solder. If not it might be cheaper than a radiator shop to buy a solder gun or iron and solder. The area must be clean and dry for the solder to adhise properly. It can be done if your a DIY person.
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
