88 Irocz Heater/ac Control Panel
Old Nov 11, 2005 | 06:28 PM
whytspeeddevil's Avatar
Car: 87 iroc-z ba boom!
Engine: V8 305 ( dont be fooled) =]
Transmission: TH-700R4 beefed up
Hi, im restoring my 88 Iroc-z. Im having a problem with the heater control panel. The problem is that i hear the blower motor working but when i switch to heat nothing comes out of the vents? I tried to switch to lo, fan, med, then High but really nothing. I was wondering if there is some sort of duct or door that opens and closes, thow i might add that the cable swtiches to cool or heat with no problem but still no heat, I feel it very faint in the defroster part. any help will be greatly appreciated. thanks guys. Oh, i forgot to also mention that whatever i switch to whether its normal vent, vent, or defroster...i get nothing.
Old Nov 14, 2005 | 05:40 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
well this is just my 2 cents but maybe something is blocking the cowl, look down inside there for crap. there is a door that the one lever works but i think that regardless if that works or not you should at least feel air coming through the vents
Old Nov 14, 2005 | 06:16 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'd also check the control panel too... it's easy to accidently pull a line off the back.
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Sep 23, 2015 05:30 PM
dbrochard
Sep 7, 2015 09:41 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
