mph difference
Old Nov 19, 2005 | 05:01 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
mph difference
i have an 87 trans am with an 87 camaro rs posi 2.73 posi unit, at 60 mph, im doing 1500 rpms, i recently put a set of 3.73 posi unit in it as was wondering if anybody has done this and knows what the mph difference would be now, i was told around 15-18 mph off. Does anybody know exactlly the difference, and have you ever had it sent off to get it calibrated.
Old Nov 19, 2005 | 07:03 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
your on the cooling board, someone is drivetrains should be able to help you
Old Nov 19, 2005 | 08:39 PM
Car: 87 trans am
im sorry but why does it say rearends on the listings of things to talk about
Old Nov 19, 2005 | 08:43 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
3.73/2.73=1.366 or 36.6% off. It is not a specific mph off, just a percentage at any given speed. And yes, this is the wrong board.
However, if you have an auto with 215/65/15, 235/60/15, 255/60/16 tires or a roughly equivalent 26" diameter the correct speedo gears are 45 and 15.
Old Nov 20, 2005 | 01:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Rear end cooling.
BAMiller
Sep 14, 2015 06:38 PM
fasteddi
Sep 10, 2015 09:32 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 2, 2015 03:39 PM
