What's the best temp for a Thermostat?
Old Dec 11, 2005 | 11:59 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I live in So. Cal so cold weather isn't a factor.
My car seems to run best before it completely warms up.
Lately my car begins to overheat on hot days when sitting at stoplights.
Running on the freeway it's fine. Only 1 fan ever comes on.
I was wondering if putting in a lower temp thermostat would help.
AutoZone sells 3 temps 160, 180, and 195.
Any ideas would be appreciated.
Old Dec 11, 2005 | 02:36 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
SEARCH SEARCH SEARCH. First thing is check your air dam.
Old Dec 11, 2005 | 03:20 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Thermostat
Hi,
Another option is the GM 170 stat
Later
Irocing
Old Dec 11, 2005 | 03:21 PM
Ice Fisherman's Avatar
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
Since it runs cool on the freeway it's unlikely to be the air dam or thermostat. I would suspect the second cooling fan first, then maybe something else like water pump or radiator.
EDIT: I checked the 91 manual, the second fan is supposed to come on when the A/C is on, the first comes on when the temp hits 230*
Old Dec 11, 2005 | 04:09 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I checked to see if the 2nd fan comes on with the AC
but the clutch to the AC isn't working so it doesn’t come on.
Back when I got my first car and smog devices didn't exist.
I used remove the thermostat all together and had no problem.
The good old days when you only needed fuel, air and spark.
No sensors to go bad. No computers to turn things on and off.
Fans where mechanical and turned with the engine.
I Know I'm just rambling on.
Old Dec 24, 2005 | 01:48 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
use at least a 180
I would recommend @ least a 180 degree thermostat. so you can get the oil warm enuff in the motor to burn off any condensation that builds up.
how far do you drive it in a day ? in one trip or do you start and stop it alot before the engine has a chance to fully warm up?
this really apllies in the colder months only
but all my cars and truck use a 180 thermostat with no problems
look in sig
Old Dec 26, 2005 | 05:54 PM
jaykar's Avatar
Thermostat
Agree on the 180 norminally.
But if you are running modded motors, higher Comp ratios, ect.
fighting detonation and slightly on the edge as some are here,
the 170 is a good choice. That also assumes that you warm the
motor up before laying on it and not starting and going down to
the corner for a 6Pac and back In the warmer climates its
also a good hedge against problems as listed above.
Its all in the application
Jus my 2 centavos
Later
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
