Air Control Assembly Installed, ONLY HOT AIR COMES OUT!!?
Old Jan 17, 2006 | 08:47 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Alright as you all know I had a problem with the air control switch on my air control assembly so I bidded on e-bay and bought a mint condition 3rd gen air control http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
I installed it right now and connected all the plugs where they are supposed to be and connected that thin steel wire that is under the assembly, connected that to that thing that looks like a hook (broke the light socket i'll get a new one at the junkyard) anyways I installed everything correctly and now the only things that work are the speeds and the air only comes out through the defroster and bottom vents what gives??????? is there some sort of special way of doing it?
Old Jan 17, 2006 | 08:50 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
old peice
Old Jan 18, 2006 | 06:07 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
found the problem... I routed the vacum hoses wrong :-p
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
86IROC112
Sep 7, 2015 01:37 PM
jackhammer
Aug 15, 2015 10:04 PM
