constant flow thru heater core = warmer temp?
Old Feb 23, 2006 | 06:26 PM
llvll4l2c91350's Avatar
just curious if removing the heater valve and all those lines and running straight hose from the radiator to the core then back out would make the engine temp run a lil higher?
Old Feb 23, 2006 | 08:08 PM
MdFormula350's Avatar
well i have heard from some people to turn the heat on if your overheating some, to let to heatercore take some temperature out of the coolant. so i would figure if anything the engine would almost keep alittle cooler.
usually u dont want to run coolant through the core all the time, at least it seems that some dont think its a good idea.
Old Feb 23, 2006 | 09:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cars had coolant running through the heater core constantly for years before bypass valves started appearing.
Old Feb 23, 2006 | 09:25 PM
lol i understand that. but on these cars, would it make the engine run warmer?
Old Feb 23, 2006 | 09:29 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Only if you have a "magic" heater core that somehow adds heat to the coolant.
Old Feb 24, 2006 | 06:51 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
LOL
Old Feb 24, 2006 | 11:49 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
My car runs COOLER once i reconnected the heater core (it was bypassed with a hose, kinked).
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
Formula8r89
Sep 22, 2015 04:24 PM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
