my radfan wont turn on
Old Feb 19, 2006 | 12:58 PM
jkwild0630's Avatar
Car: 86 camaro z28
Engine: 5.7 carb
i have a 92 firebird auto 3.1
i change my relay and still nothing, now do i test the fan to see if the fan is bad, or is there something else can be the problem
Old Feb 20, 2006 | 07:11 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FANTASTIC IDEA
<CENTER><B>Yes JK, that is the next logical step. Put 12
volts across your fan leads and you’ll find out if it works.</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
Old Feb 22, 2006 | 11:53 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
I had the same problem. Checked the relay, etc....
Does it turn on when the A/C is engaged? Or does it not work totally? MY fan did when the A/C was on, but if it was off, the car would overheat. It was the fan switch. I replaced that and it works great.
Old Feb 24, 2006 | 01:37 PM
bfox88's Avatar
Car: 90 IROC-Z
had the same problem, replaced my relay switch, and it didnt do anything. turns out the wires that hook up the switch had burnt up. check the wires
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
