Where to put my thermostat
Old Feb 24, 2006 | 12:14 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
I just installed a set of dual fans on my 84 Z28. I hooked the first fan up to the EMC connection. The second fan is controlled by an aftermarket a hydraulic thermostat switch that I can set to come on between 0 and 260 dgrees. But where to put the thermostat? currently I have it placed in the lower right hand corner of my radiator between two of the fins. The problems is after awhile the aluminum fins get wide and the thermostat slips out. Is there a better place, maybe on the block that people have used?
Old Feb 24, 2006 | 11:55 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I have mine 1" lower, 1"inch away from the inlet to the radiator. Use a little high temp silicone on the back part of the probe, it will hold it on. DONT COVER THE BODY OF THE PROBE!
Old Feb 24, 2006 | 10:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
When I had my rad. flow/temp tested, they made a small wall of high temp RTV on the fins, let it set, then screwed the sender into that wall of RTV. However, on mine, fins were actually cut out to make room. Again, as above, don't get RTV on the probe.
Another option (what size is your temp sensor? 1/8" NPT?) drill a hole for it in the intakes coolant crossover or water neck, tap it, and install it there.
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
